Trying to bring an RR5 back from the dead
Old Jun 7, 2018 | 02:25 AM
Chillitt's Avatar
Default Trying to bring an RR5 back from the dead
Got a bit of a project going. The bikes been dropped and the forks need sorting, but its also been sat under a cover for 7 years. I've had the tank off, its rusty and the petrol in it was like cola. currently I'm electrolysising* the out of the tank, but the pump is pretty clogged. I've taken the mesh out and cleaned that, but I'm not optimistic about the pump working. Trying to keep the costs down and a new pump looks expensive. and I cant find an oval 2nd hand one. Can I fit an earlier tank with the round filter? Also, not sure what I need to do to the rubbish out of the rest of the system as never tinkered with an injection bike,,
*Is that a word?
Old Jun 7, 2018 | 07:20 AM
CaBaRet's Avatar
Your looking for 05-06, here's an after market pump kit 01-06
https://www.ebay.co.uk/itm/New-EFI-F...8AAOSwKOJa0B0h
Old Jun 7, 2018 | 07:30 AM
Chillitt's Avatar
Thank you! I scrolled past all of those as it looks nothing like what I have now I was lead astray by the Haynes manual saying theres nothing to be done with the assembly.. I will wait until I've found my soldering iron and removed the alarm so I can check it properly, but that looks just the job.
Old Jun 7, 2018 | 11:18 AM
CaBaRet's Avatar
Is it only the Haynes Manual that you have, look here
StephyGee.com
Old Jun 7, 2018 | 11:43 AM
Chillitt's Avatar
StephyGee.com
Oh, thats much better. Thanks again.
Old Jun 9, 2018 | 01:57 PM
Chillitt's Avatar
Finally found the soldering iron so the alarm is toast. Pump relay clicks but pump does nothing so I've ordered the kit. A quick squirt of carb cleaner up the pipe and the bike ran, albeit very briefly for the first time in 7 years so there is progress. There's a crack where the alternator cover had a short argument with the M25 to sort out next..
Old Jun 9, 2018 | 02:00 PM
CaBaRet's Avatar
Good to see things are happening , keep us informed
Old Jun 9, 2018 | 02:06 PM
Chillitt's Avatar
When it's this rough, making progress is easy.
Old Jun 9, 2018 | 02:19 PM
CaBaRet's Avatar
Gosh , I thought it was all together, just another thing ,it would be a good idea to bypass the safety stuff , BAS ,Clutch Switch and Sidestand switch, as the BAS is part of the Light harness , it will need bypassing on the harness, remember the PDF manual is USA there are slight differences (Hiss) so stick to the Haynes Manual for Wiring diagrams, maybe the BAS is stopping it starting
Old Jun 9, 2018 | 02:33 PM
Chillitt's Avatar
Previous owner got this far into fixing it, painted everything black and then some good friends had some bad luck on bikes so it sat there. We had to move it like this through the house to get it out.. Next thing the engines coming out to sort that crack so there will be hardly anything left... I'm going to sort it mechanically and hand it over as I have loads of work on with a similar deadline so might not get to do too much in the way of extras (unless the steel delivery is late again..) and I certainly not touching the cosmetics, thats a job for an enthusiastic new owner. will be good to give him a list of jobs to do when we hand it over.
