Swing Arm Trouble
Old 02-18-2008 | 02:43 PM
jfunkRR's Avatar
Default RE: Swing Arm Trouble
ORIGINAL: Stockrocket
When I removed my swingarm the shock and sh** was still connected. After having the swingarm off I removed the rear shock. Didnt seem all to bad once I got it apart, just hope I dont forget how to put it all back together by the time I get my PCed parts back.
Check this link:
http://www.willowsmotorsports.com/fi...ion_detail.asp
(select swing arm from drop-down menu)
See if it's any different than your '06.
EDIT - I'm also going to PC the dog bones and sub-arm assembly...any trouble with these pieces?
Old 02-18-2008 | 04:04 PM
longbeachboy's Avatar
sweet....i got my swing arm off...i had to go to a hardwear store and by that bolt...but other than that, it was fairly easy...i think tha black forks look good on that all black bike...but yeah..thanks for tha help...wat other project pieces are u gonna do....i've been tryin' to figure out a new paint scheme for my bike...have any ideas?
Old 02-18-2008 | 09:23 PM
jfunkRR's Avatar
I got mine off tonight after work and didn't have to remove the exhaust...it came out easily with the shock on it after I took out the lower shock mount bolt and the pivot shaft. I'll probably spend the next week pulling all the bearings out of the sub-arm assembly, the dog bones and the swing arm, but it'll all be worth it when they come back black!!
Here ya go Rocket, ya won't forget...
Old 02-19-2008 | 12:16 AM
FITZ's Avatar
Man i really wanna get mine powder coated, I even get it for free. But there is no way I would get that back together. Post pic once you get it completed. I love the blue 04 rr
Old 02-19-2008 | 09:59 AM
jfunkRR's Avatar
ORIGINAL: FITZ
It's really not that bad, Fitz...after the tire comes off, it's two more bolts...the pivot arm shaft and the lower shock arm mount bolt...and it drops right out. Both shafts can be seen below the bike in that pic.
The tricky part is going to be pulling all thosebearings out of the dog bones and lower shock arm assembly. The swing arm bearings shouldn't be too bad.
FYI - I've been advised to just pull the bearings out for the pc process. Some riders on here have suggested to keep them in, and to wash the grease out. But why not just pull them, wash them outside the bike and re-grease and put back in? One of my wrenching buddies said some of those needle bearings have plastic sleeves inside them, that would melt during the pc curing process. Why risk it? I'm just gonna pull them all out, and hopefully I don't destroy them or I'll be spending a small fortune on replacement bearings. We'll see how it goes.
Old 02-19-2008 | 10:31 AM
Stockrocket's Avatar
Ya just dropped off my tires and swingarm to getthe bearings pressed out and tires taken off so I can get the PC goin. If all goes well it will be back together in time to ride this weekend but I dont think i could get that lucky.
Old 02-21-2008 | 10:09 AM
jfunkRR's Avatar
See this thread for s/a bearing removal...
https://cbrforum.com/m_470690/mpage_.../tm.htm#490517
Actually, just post there so we can combine these two threads...
WildWill
03-21-2009 10:10 AM
Derick19
09-14-2008 06:46 PM
SERGIOC
06-05-2007 09:03 PM
Triax
08-25-2006 01:34 PM
Drake
05-24-2006 02:52 PM
Quick Reply: Swing Arm Trouble
