Single sided
Old Jan 29, 2008 | 11:41 PM
CBR_600_Rider83's Avatar
Default Single sided
Ok I would like to put a single sided swing arm on my bike dose anyone know where I could find one make for an 05 CBR 600RR?
Old Jan 30, 2008 | 10:44 AM
vfrrider's Avatar
Default RE: Single sided
SSS for just about any bike is usually the VFR 90-93 or 94-97 (little differences). Use the rear wheel from the 90-93 (8 spoke) or 98-present (5 spoke). Get the whole SSS, with caliper, master cylinder, rotor, and shock linkage. Your present shock MAY have to be used. Usual mods include a little judicious grinding to fit in the frame (SSS tends to be a little wider than frame, +- 1/4").
Later model VFR SSS (98-present) is NOT preferred due to the fact it connects to the engine and not the frame as in previous versions.
They come up periodically on EBay.
I have 8 spoke wheel available, as well as a chromed set from the 90-93 bike, with front rotors and tires. Same front wheel as F2-3.
Larry
VFRrider
yorkiejeff
F2 Tech
Aug 6, 2015 03:32 PM
dmiles929
Apr 22, 2009 07:47 AM
f4ighter
Jan 12, 2009 06:15 PM
lococbrf2
Oct 17, 2007 05:33 PM
AzNBoI_585SF
Jun 8, 2007 09:44 PM
