Single sided swinging 929???
You need a 98 or newer VFR 800 arm. Will need custom bushings for the swing arm bolt and to shave a little off the swing arm. I am doing this to my 00 929. As to why? Well it looks bad ***. Does not degrade handling that much if you keep the same wheel and tire size. Or this swingarm uses a standard 4x100 bolt pattern so for not that much money you could have a wide wheel with a 240+ tire. All depends on what you want.
