Running hot
Old 04-07-2005, 09:51 PM
trick80's Avatar
Default Running hot
I was just wondering what other 600RR's usually run at temperature wise. Mine runs kinda hot compared to my last bike. I've actually seen it get to 230 on a hot day at a stop light. Just wondering if that's normal because I checked the fluids and they were a little low but it still runs the same after I filled them up.
Old 04-07-2005, 11:23 PM
Default RE: Running hot
Yes, it is common on hot days for it to hit those temps. My bike will consistently go into the realm of 225 on a hot day when not moving.
BTW, the electric cooling fan kicks on at 219. That should give you an idea that it is normal.
Old 04-10-2005, 11:16 PM
that is faily normal for this bike. i changed my coolant to a product called engine ice, i was told it was really good so i tried it and my bike run around 200 normally and 210 on hot days, you could try it and see how your bike reacts.
Old 04-11-2005, 12:28 AM
I bet you get some pretty hot days in NM. That is normal for it to hit that temp. Once you get moving again it should cool down quite a bit.
Old 04-11-2005, 10:27 PM
177-185 from 30 MPH and up while sitting goes to 222 fan comes on drops to 214 and cuts off running the same as any car would I am also in IL and not seen over 85 F yet
Old 04-11-2005, 10:30 PM
177-185 from 30 MPH and up while sitting goes to 222 fan comes on drops to 214 and cuts off running the same as any car would I am also in IL and not seen over 85 F yet not all therms are the same they all have a range they have to stay in I am guessing + or - 10 degrees for the fan. I prob would not worry about unless it goes over 230's and does not drop that much during movement
Old 04-11-2005, 11:56 PM
trick80's Avatar
ORIGINAL: eric
I think I will try that cause it's not even really hot yet for NM and i've already seen it get to 230 on a day when it was only 77 or so. It should usually be in the high 90's within the next couple of months. Can't wait though, finally some sweet riding weather.
gundamknight07
07-26-2012 08:24 AM
motogpman
08-28-2009 07:10 PM
entity-unknown
03-20-2009 11:55 AM
motoman358
07-02-2008 08:59 PM
Kym
06-22-2008 07:33 PM
Quick Reply: Running hot
