98 CBR 900 rr not running right
Old Jul 17, 2012 | 11:18 PM
gundamknight07's Avatar
Smile 98 CBR 900 rr not running right
I'm on here for a friends sake My buddy bought a 1998 Honda cbr 900rr fire blade it was in pecieces i know nothing about bike but alot about engines i was able to get the engine rebuilt and back together in the bike carbs hooked up and every thing but for some reason it's not firing on all cylinders i checked compression i check the plugs and wires and coils all are working it's throughing fire out the exaust and fuel out all four carbs so i checked the timing trigger and rotor there working as well to could it be a bad vacum leak or did i set the cams wrong it will run on it's own but very badly
Old Jul 18, 2012 | 12:03 AM
Shadow's Avatar
I'd say your cam timing is out.
Old Jul 18, 2012 | 12:09 AM
cobra1000rr's Avatar
sounds like its overloading with fuel, the fuel petcock could be bad and flooding it out bad like mine was doing. the fuel petcock is a common problem with dumping fuel into the carbs, etc. I would start there could be a good start.
Old Jul 18, 2012 | 09:07 PM
where running it off an aux tank the carb floats are working cause i dn't see any excess fuel sitting or flowing out
Old Jul 18, 2012 | 09:08 PM
me and my friend will try that
Old Jul 19, 2012 | 09:50 AM
If you have built the motor you could have your timing off, or cams, etc. How did you line up no. 1 cylinder etc. Did you have a manual to help rebuild it?
Old Jul 20, 2012 | 06:23 PM
the cams where off and yes we do have a book we got the timing fixed but now it's running on three cylinders still better than what it was my uncle told me we might have a weakend coil could you explain that
Old Jul 21, 2012 | 09:15 AM
I would check the coil and the fuel to that cylinder. Be sure your getting both, the manual should tell you specs on teh coil to ohms test it for proper readings. Easy way could be to check for spark hold the plug wire close to metal and crank it over, see if it sparks. also check the color of the spark, I think a yellow/orange spark is weak, blue is good. to ohms test you will have to check within the manual.
Old Jul 23, 2012 | 01:21 PM
Default 98 CBR 900 RR not running right
I got the bike working the coils where wired backwards running freat but where having transmission issues 2nd gear grinds and now 3rd pops out
Old Jul 23, 2012 | 11:42 PM
That's not good, did you have to rebuild the motor trans and all? if they guy you bought it from wheelied it and stripped out the trans - might be why he tore it down.
