Radiator Repair/Fix
Radiator Repair/Fix
Good Afternoon..real quick..ive got an 89 CBR..getting rid of to make room for an 03 RR..ahhhh...OOOOO... but i need to repair a radiator either have it fixed or get a new one.I seen one on bikebandit and they wanted 495.00 but im not sure if thats the going price or if anyone has any insider info on aftermarket or bike part scraps.Thanks Ahead of time.
RE: Radiator Repair/Fix
Take it to a radiator repair shop and try to get it fixed first. After puncturing the radiator in my 05 600RR I had it fixed for a total of $50.00. If you have to by one check out www.ronayers.com. They seem to have the best internet prices on OEM parts.
you can use jb weld or some other high temp steel/ aluminum epoxy to patch it up if it's just small leaks... I had a rock puncture the aluminum core on my car but it only bent a couple of fins didn't go all the way through... so I just pulled it out, drained the coolant and sealed it up... works great. if it took out like a whole coolant row though you will probably need to get a new one.
No way dude, there was no paper clip involved. Just the egg whites. In fact, this was even on an episode of Mythbusters. They didn't use no stinkin paper clips either, just the egg whites. The results...... myth CONFIRMED. It really works.
ORIGINAL: NINE2NINE
now don't go and mislead people. macguyver used a paper clip with the egg whites. GET YOUR FACTS STRAIGHT BEFORE YOU POST! *****
ORIGINAL: kiggy74
Put some egg whites in it. It worked for MacGuyver.
