Question: 600rr brake light
Old Nov 1, 2007 | 05:32 PM
DeeQcbr's Avatar
Default Question: 600rr brake light
Hi everyone,
I just bought an 05 600rr . My brake light doesnt light up when i step on the rear brake , did i burn a fuse or something ?!?
Thanks .
Old Nov 1, 2007 | 05:38 PM
sixhundredrr's Avatar
Default RE: Question: 600rr brake light
ORIGINAL: DeeQcbr
Hi everyone,
Thanks .
Do you have the key on? It won't light up w/o the key on. Now, if it still doesn't light, you have a problem and should check fuses for burned out ones. I believe the box is beneath your seat. If you did blow a fuse, it could be a sign of a bigger problem like a short in the wiring or improper installation of an A/M taillamp. Let us know what you find.
Old Nov 1, 2007 | 05:53 PM
patas75's Avatar
Do you have aftermarket rearsets? If so you may have to get a hydraulic switch to get it to light up. Aftermarket rearsets usually get rid of the brake light switch.
Old Nov 1, 2007 | 05:56 PM
skical's Avatar
You say "The Rear Brake". What happens with the Front Brake???
Old Nov 1, 2007 | 07:23 PM
TXCBR07's Avatar
Sounds to me like the small spring underneath the rear brake pedal might have slipped off. Look underneath and you'll see where a small spring connects with your brake pedal. Same thing happened to me - it's a quick fix.
Old Nov 1, 2007 | 09:50 PM
DeeQcbr's Avatar
key on and still doesnt light up . The front brake work fine.
Aftermarket Interated tail .. Whats a hydraulic switch ??
Ill check the spring , fues, hydraulic switch tomorrow when i install my frame sliders.
Thanks for all the comments guys [sm=smiley20.gif]
Old Nov 2, 2007 | 11:50 AM
meanstrk's Avatar
You need to adjust the brake light switch for the rear brake then.
Old Nov 2, 2007 | 02:27 PM
baxsom's Avatar
ORIGINAL: meanstrk
seems common for the at least the 07 600rr. i have read more than one posts (mine included) where that has happened. just turn the plastic screw holding the rear brake switch on the stock rearset until the brake comes on when you want it to
btw a hydrolic switch takes the place of the oem one where the switch recognizes hydrolic pressure and completes the circuit
Old Nov 2, 2007 | 03:48 PM
TXCBR07's Avatar
ORIGINAL: baxsom
ORIGINAL: meanstrk
I had to do that same thing this morning before heading out in fact. Glad I'm in the habit of checking everything. Guess the MSF training really sticks!
CBRSeanF4
Apr 15, 2014 07:51 AM
03cbrsix
Aug 14, 2009 06:27 PM
eljrc16
Jun 27, 2009 01:12 PM
ACSHoops33
Jan 21, 2009 07:22 PM
camaropower
Dec 3, 2008 09:13 PM
