Question: 600rr brake light
Hi everyone,
I just bought an 05 600rr . My brake light doesnt light up when i step on the rear brake , did i burn a fuse or something ?!? Thanks . |
RE: Question: 600rr brake light
ORIGINAL: DeeQcbr Hi everyone, I just bought an 05 600rr . My brake light doesnt light up when i step on the rear brake , did i burn a fuse or something ?!? Thanks . |
Do you have aftermarket rearsets? If so you may have to get a hydraulic switch to get it to light up. Aftermarket rearsets usually get rid of the brake light switch.
You say "The Rear Brake". What happens with the Front Brake???
Sounds to me like the small spring underneath the rear brake pedal might have slipped off. Look underneath and you'll see where a small spring connects with your brake pedal. Same thing happened to me - it's a quick fix.
key on and still doesnt light up . The front brake work fine.
Aftermarket Interated tail .. Whats a hydraulic switch ?? Ill check the spring , fues, hydraulic switch tomorrow when i install my frame sliders. Thanks for all the comments guys [sm=smiley20.gif] |
You need to adjust the brake light switch for the rear brake then.
ORIGINAL: meanstrk You need to adjust the brake light switch for the rear brake then. btw a hydrolic switch takes the place of the oem one where the switch recognizes hydrolic pressure and completes the circuit |
ORIGINAL: baxsom ORIGINAL: meanstrk You need to adjust the brake light switch for the rear brake then. btw a hydrolic switch takes the place of the oem one where the switch recognizes hydrolic pressure and completes the circuit I had to do that same thing this morning before heading out in fact. Glad I'm in the habit of checking everything. Guess the MSF training really sticks! |
