Proper wiring?
Old Nov 11, 2007 | 06:50 PM
WhiteDealershipRice's Avatar
Default Proper wiring?
I am currently upgrading my signal lights to LEDs, but evrywhere I've read, the 600RRs (mine is an 07) can't replace the flasher timer/relay to bring the flash rate back down.
I'm debating wether to just let them flash fast or to add resistors to all four corners.
Does the faster flash rate/ lower electrical draw damage the flasher, or is the only consideration to slow the flash rate to pass inspection?
I'm not electrically savy, so I included a diagram on 3 possible ways to wire the resistor, (if I decide to actually wire them in) which is the correct one?
[IMG]local://upfiles/12341/519F419A9A194B53B3317A59B8E2F3C0.jpg[/IMG]
Old Nov 11, 2007 | 09:35 PM
mycvil's Avatar
Default RE: Proper wiring?
I'd sayoption 1 iscorrect. - I believe you need to take it from the + (Flashing) to Ground - so you run it parallel to the light. - At least that's the way my LED taillight said to wire it in. - I think if you put it in line with the light, the voltage going to the LED's would drop, and they would not operate at an acceptable brightness.
Old Nov 11, 2007 | 10:07 PM
alekinci's Avatar
^ pretty much right.
option one is how you should go with the led.
careful using higher wattage resistors, they do get hot. some dude on this forum used a 8ohm 10watt and it melted the fender and tail fairing.
go with higher resistance and lower wattage. my 2 cents.
Old Nov 13, 2007 | 04:08 PM
james007torres24's Avatar
if i remmber correcty i think its 2 or 3. for leds. i have my in but i dont remmber.
PS u dont have to do all 4 sides..... the left front and back are together. and the right left and back lights are tother too. so its only 2 u have to add not 4.
PS #2 some led turn signals some with them built in so u might want to check first.
Dazed
Aug 12, 2011 05:18 PM
iceman423
Jun 10, 2010 05:24 PM
ccain
Aug 15, 2009 06:41 PM
cuban b
Mar 13, 2009 09:54 AM
ibedanny
Apr 11, 2008 02:29 PM
