Problem with Vehicle speed sensor (VSS)
Old Dec 19, 2011 | 07:39 AM
RTAF's Avatar
Default Problem with Vehicle speed sensor (VSS)
I have a problem with vehicle speed sensor. I use the oscilloscope to monitor the output. It's a square wave with peak voltage about 1.2-2 volts.
Wiring diagram:
Black = +12V
Green = GND
Pink = Output
From CBR600 Manual, when the wheel is turning the output should be repeat 0 to 5V.
It's engine of student formula car so it doesn't have a tachometer or dashboard.
I test the sensor without assembly into car. When the metal is near the sensor, output is 1.90V.
I have 2 sensors and the test result is the same.
Uploaded with ImageShack.us
Beez Motorsports
Oct 15, 2012 06:33 PM
chetman7
May 4, 2010 12:52 PM
bjenev1
Mar 11, 2009 12:52 AM
dscort
Feb 1, 2008 03:33 PM
birdee
Aug 12, 2007 06:12 AM
