PLEASE HELP!! 600rr stalling
Old Apr 26, 2008 | 01:46 PM
lukestad's Avatar
Default PLEASE HELP!! 600rr stalling
I was adjusting my idle rpm the other day by twisting the idle adjustor cable and it came off. Now the bike idles at around 700rpm and stall whenever it is revved. What is involved in getting this cable back in its proper location. I believe it connects to the throttle body.
Old Apr 26, 2008 | 04:30 PM
Woody6799's Avatar
Default RE: PLEASE HELP!! 600rr stalling
wow how hard were you pullin on it? First I have heard of something like that... my word of the day is "replacement"...
Old Apr 26, 2008 | 04:34 PM
crashkhanman's Avatar
Why were you adjusting it in the first place if I may ask?
As i'm aware the '07s did away with any manual idle speedadjustments. At idle speed, the '07 - '08 bikesuse the ECM tocontrol the IACV which gets information from the ECT to maintain correct idle speed during warm up. When the throttle is opened or the ClutchLever is released while in gear,the IACVslides close.The only adjustment that can be made is in throttle cable free play(which you can adjust the amount of free play, both on the upper side of the throttle cable and lower side near the throttle body).
You will need to check/set your throttle cable freeplay. This should help with your idle problem. What ever you do... DON'T snap the throttle valve full open to full close while throttle cable is removed. This can cause incorrect idle operation.
Here's a picture of how the throttle cables attach to the throttle drum.
Directions on how to check your throttle free play and make adjustments.
If adjusting your throttle cable back to proper settings does not correct your problem... you might have a faulty IACV.
Old Apr 26, 2008 | 09:57 PM
lukestad's Avatar
What do I need to remove to get access to the throttle body? I just need to screw the cable in. I think I need to remove the gas tank.
Old Apr 26, 2008 | 11:57 PM
You need to remove the Gas Tank and The Air Box.
tmoore
F2 Tech
Nov 22, 2011 10:15 AM
racerx450r
Apr 8, 2010 10:49 PM
atr3yu baykor
Feb 6, 2008 05:55 PM
03CBR1k
Aug 1, 2006 06:56 AM
Crave
Mar 24, 2006 11:08 AM
