Parking Lights...
Old Oct 21, 2006 | 07:57 AM
Blue Fox's Avatar
Retired Moderator
Default Parking Lights...
Had an idea......Wanted to see if anyone has heard of or knows how to mod the bike so when you turn it on with the kickstand down, all lights are on EXCEPT for the headlights. Then when you put the kickstand up, the headlights will come on as usual.
This would be most helpful when warming the bike up. I feel bad when I let the bike warm up at night when my headlight is glaring into neighbors windows and such. I could also think of a dozen other places where it would be useful to have "parking lights" instead of having the headlight on all the time when the key is turned to the on position.......I think it makes perfect sense.
Seems like a good idea. But how the freak would you even do this? (Any Electrical Engineering majors out there?)
Old Oct 21, 2006 | 11:09 AM
doncollins's Avatar
Retired Administrator
Default RE: Parking Lights...
You could use the wiring on the side stand switch. Continuity (I assume negative) exist only when the side stand is up. So use this (if negative) continuity as the ground for your low beam headlight relay. There is a green plug just forward of the shaft where your shifter linkage connects to. Here are a couple of pictures to help:
Size:  15.2 KB Name:  headlamprealy.jpg
Use a multimeter and verify that the continuity in your side stand wiring is a ground (negative) then tastefully run a wire from this connector up to your headlight relay and replace the ground (which ever Bl/R or Bu is negative on the headlight relay) with your new wire.
What's this doing? It's removing the factory ground for your low beam side and replacing it with a ground that only exists when your side stand is up.
Low beam only because you can turn your high beam off at the switch. You can do the same with the high beam side, but why would you need to?
Old Oct 22, 2006 | 03:21 AM
liltoland's Avatar
I have an 06 and put in a switch up on the dash to turn my headlight off. I had the same problem and didn't wanna make the neighbors mad.
Old Oct 22, 2006 | 07:09 AM
Blue Fox's Avatar
Retired Moderator
Don Collins, thanks man. That helped me out TREMENDOUSLY. Now to attempt it for real.
Thanks again man.
xankriz
Apr 2, 2012 03:02 PM
Rizznutz
Apr 27, 2008 11:04 PM
2QK4U2C
Oct 2, 2007 08:04 PM
outsider8
Oct 22, 2006 05:03 PM
ChrisMcD
Feb 23, 2006 06:15 PM
