operating Temps...
Old Sep 12, 2005 | 12:23 AM
Tribal_Steve's Avatar
Default operating Temps...
Hello Gang. What kind of operating temperatures are you seeing on your rr's? The other day, was only in the 80's outside.... moving slow, I seen 220 on my '05.... regular cruising is anywhere from 175-185 usually... this alarmed me, and seemed a bit high. I'm sure it was contributed to my lack of forward motion (maybe 25 stuck behind a farm tractor). Anyone else seen temps this high?
On a side note, I did finally decide on exhaust... Two Brothers, Small Oval, Carbon Fiber... will be here tomorrow. Tonight I finished the Comp. Werks Fender Eliminator... Ok design I guess, but not worth the money IMHO... I could have made a fixed tag bracket myself, and just gotten a taillight with integrated signals. Now that I got it on there and seen it, there is room to angle the tag up more then it sits, and actually still be able to see it, so I could have made something fixed... oh well.. I didn't bother to put on the signals, I'm just going to go integrated tail... I'm not a fan of cutting factory wires.
-Steve
Old Sep 12, 2005 | 08:07 AM
doncollins's Avatar
Retired Administrator
Default RE: operating Temps...
I did 800 miles over the week-end. Temps were from 70's in the mountains at night and 80's during the day. The temps you noted are the norm. The fan is designed to kick on at 219 if that's any comfort to you. When I'm not moving, at traffic lights and so on, it climbs to 220 quickly but the fan holds it at that. I've only seen a few degrees higher than that, never above 225. Cruising speed of 60 up to 110 it stays around the 170 to 180. I know this is norm, but has anyone ever tried water wetter? It claims it can improve the heat transfer of ethylene and propylene glycol systems? http://www.redlineoil.com/products_coolant.asp
Old Sep 12, 2005 | 10:45 AM
RiPTOR's Avatar
Your temps are fine. High 70's cruisin around yesterday. After bout a 40 minute cruise my temp got up to 223 at a stop. Nothin to worry about.
Old Sep 12, 2005 | 01:15 PM
josho66's Avatar
ORIGINAL: RiPTOR
That is pretty much what mine does. ON a normal 70 or 80 degree day it will run about 190 or so at 65 MPH. When I am in town or stopped it wil be between 215 and 225.
Old Sep 12, 2005 | 01:35 PM
kiggy74's Avatar
Sounds normal. At about 225 you'll here the fans kick on. I've heard some people say that they turn their engine off when the temps get this high, even if they're at a light. Don't do that, it will end up getting hotter yet because you'll be turning the fans off too. 225 won't kill the bike.
BTW, I have a friend who rides a Ducati Supersport 800. It's air cooled, and the normal temp while riding is 220-250 deg! Get's to 280 deg at lights.
Old Sep 13, 2005 | 12:27 AM
Kewl. Thanks for taking the time to reply guys.
-Steve
Old Sep 13, 2005 | 03:10 PM
RiPTOR's Avatar
Actually... the fans stay on as long as they key is set to ignition, the engine does not ahve to be running. After a long ride ill pull in home and just kill the engine, leaving the key set to run... the fans will run until it is cool enough.
Old Sep 13, 2005 | 03:51 PM
kiggy74's Avatar
Good to know.
Cavscout73
Apr 20, 2009 01:04 PM
CBR900RR_JAPAN
Aug 14, 2007 12:16 PM
jjhz83
Mar 26, 2006 01:49 PM
PierPressure
Feb 20, 2006 11:57 AM
tims626turbo
Feb 27, 2005 12:31 PM
