master cylinder leak
Old 04-05-2006, 12:23 AM
duck0872's Avatar
Default master cylinder leak
I've noticed lately that I'm leaking fluid from my front master cylinder. It's coming out from the seam where the cover contacts the master cylinder. I've taken it apart and the gaskets and everything look good. Any ideas how to fix it??
Old 04-05-2006, 11:48 AM
Default RE: master cylinder leak
Your talking about where the brake line T's on your front tire cover? Coming from the resivoir to the front goes into a T fitting to both ur front calipers?
Old 04-05-2006, 08:45 PM
If you had it apart and filled it or if you had the calibers off and squeezed them back to get the pads back in and on it will cause one to leak other wise its dirty and i think i would buy new screws when you turn them loose ive saw too many of the heads strip out, hope this helps.
CBR forever
F4i - Wanted
10-19-2013 01:01 AM
CJardine
01-13-2012 10:00 PM
gt900uk
05-06-2010 04:36 AM
Quick Reply: master cylinder leak
