master cylinder leak
I've noticed lately that I'm leaking fluid from my front master cylinder. It's coming out from the seam where the cover contacts the master cylinder. I've taken it apart and the gaskets and everything look good. Any ideas how to fix it??
If you had it apart and filled it or if you had the calibers off and squeezed them back to get the pads back in and on it will cause one to leak other wise its dirty and i think i would buy new screws when you turn them loose ive saw too many of the heads strip out, hope this helps.
