Leaking Oil... Again...
Old May 25, 2022 | 03:15 PM
2012CBR's Avatar
Angry Leaking Oil... Again...
I have a 2009 CBR600RR which was leaking oil so I replaced the valve cover gasket and applied some honda bond. The bike sat for about 3 days and change so the Hondabond can cure perfectly.
I’ve ridden the bike for about 5 hours total since changing the gasket and there was no issue.
Today while riding the bike, I go over a speed bump relatively fast and heard a pop and saw white smoke, similar to what would happen with my bike when it first started to leak oil, before I replaced the valve cover gasket.
Being that the current valve cover gasket is new + there's some Hondabond on there, what do you guys think is the problem?
After I realize the bike was leaking oil (today and before I replaced the valve cover gasket), I drove about 5 minutes or so and the engine feels fine. There is just an oil leak. The bike didn't overheat or anything. I shut it down, turned it back on and it fired right up. There was no lights on the dash, no weird bogging or anything, etc. Just a lot of oil loss. I don't believe I over torqued the cylinder head cover being that I used a star pattern.
Thoughts as to what can be going on? Back pressure or something causing that pop sound and then white smoke? I believe the smoke comes from oil getting on the headers.
Old May 25, 2022 | 10:28 PM
Hi and welcome to the forum. The pattern you used to tighten down the valve cover bolts does not indicate how tight you made them. You need a torque wrench for that. As for the leak, I'd get some soap and water and thoroughly wash the bike and engine. Nice and clean. Then go for a ride and then after check to see if you can determine the source of the leak.
UFrider227
Jul 2, 2019 06:15 PM
RP Rides
Oct 1, 2016 10:38 PM
kmanracing24
May 23, 2010 12:14 PM
briand
Apr 16, 2010 07:17 PM
Ne0z
Sep 4, 2007 11:55 AM
