Oil leak at generater side.
Old Apr 15, 2010 | 10:24 PM
briand's Avatar
Default Oil leak at generater side.
I'm working on my sons 2005 CBR600. It seems to have oil leaking out of the generator cover. The schematics don't show a gasket. I've been working on bikes and cars for years and never seen a wet generator. Is this the case with the CBR600? My fears are maybe a crank shafy seal.
Old Apr 15, 2010 | 10:34 PM
chainstretcher's Avatar
Admin Emeritus & MVN
Is it leaking out of the cover or are you just talking oil inside the cover? A little oil in there is normal. There is usually a gasket to keep it from leaking on the ground. Did your son lay it down on the cover?
Old Apr 15, 2010 | 11:16 PM
briand's Avatar
It is leaking out of the cover filling up the bottom of the farring and then of course droops on the ground. It looks like thier is a silicone type gasket there.
Old Apr 16, 2010 | 12:10 AM
That gasket is usually the light green material. If you have stands for the bike, put it on the stands and remove the cover bolts. You should get a few ounces of oil drip out when you remove the cover. Word of warning ... put soft towels all around because the covers can sometimes be a pain to get off. The magnet pulls like crazy until that last 1/2 inch when it allows you to fling the cover across the garage floor ... hence the soft towels.
So if you get to that point and you're not getting a steady stream of oil then get a new gasket and zip her up. My experience has been that unless it was laid down hard on that side I doubt the seals are shot and it's probably just the gasket (or someone's attempt at a gasket) that is leaking.
Old Apr 16, 2010 | 07:17 PM
briand's Avatar
Well thanks for your help Chainstretcher. I think you've cleared up the mistery and set me on the right path.
Brian
elosak
Sep 16, 2010 07:44 PM
DrkSyde
Mar 9, 2010 03:25 AM
CosmoBob
Apr 20, 2007 02:59 PM
