Ignition wires cut
Old Sep 16, 2009 | 04:28 AM
badluck's Avatar
Default Ignition wires cut
My CBR600RR was stolen and recovered. They cut the ignition wires in an attempt to hotwire it. I've reconnected the wires but I still have no electrical at all. I've checked all the fuses. Does anyone have any ideas what the problem could be?
Old Sep 16, 2009 | 08:16 AM
bambam's Avatar
welcome bro, that sucks about your bike, im glad you got it back. check your main fuse, and then recheck all of your fuses , you may have a short somewere , and this will cause the fuses to blow continuously. also use a test light to test all fuses front and back sides to be sure your fuse box is getting power. if dick-thief cut wires while batt was connected , i believe your main fuse is wiped , witch is what you want to happen, this will not let any juice to the fuse box. hope this helps
rickway
Dec 13, 2014 09:28 PM
olcodger
Dec 16, 2013 04:20 PM
newnut
Aug 15, 2011 08:02 PM
TimBucTwo
Alternative Parts
Jan 19, 2010 11:25 PM
ddaren
Apr 5, 2007 12:16 PM
