Alternative Parts What fits where, what else will fit, resources + bike manuals
Ignition wires
Old Dec 17, 2009 | 11:09 AM
TimBucTwo's Avatar
Default Ignition wires
As the Honda plug wires are pricey, I am posting what I think can be substituted. The Ford Zetec motor uses very similar wires. I don't know if the smallest one will work however. The Zetec motor is used in the Ford Contour, Escort and Focus. Different manufacturers make them. If someone installs them with success, please give feedback so that others may benefit.
AC Delco #16814u
Airtex #2x1282
Bosch #09741
Champion #780478
Denso #6714058
Motorcraft #WR5730
Old Dec 17, 2009 | 07:00 PM
chitownart's Avatar
Default Wires
Why not make your own? I did with MSD wires and caps and Dyna Coils. The coils had to be mounted on a separate plate but they still fit in the stock location. If I get a chance, Ill take some pics and post.
Pricewise, about $30-40 for wires and about $90 for coils on ebay. Granted not the cheapest, but still cheaper than OEM /Dealer.
Also purchased the pliers and die heads for pinching the ends, very reasonable since I also use the pliers for other wire work.
Old Dec 18, 2009 | 08:43 AM
TimBucTwo's Avatar
I was more concerned about the plug caps. The factory ones keep debris out of the holes. The Ford plug caps will do a good job of this. A set cost about $34 USD.
You would need to get some small O-rings to slide on the wires to seal them from water at the coils. The factory ones will not be reusable. You can get them cheap from a hardware or plumbing store.
You should definitely post pictures.
Old Jan 19, 2010 | 11:25 PM
Trips's Avatar
Use the Spark Plug Caps they use on Petrol Engines 4WD's
rickway
Dec 13, 2014 09:28 PM
olcodger
Dec 16, 2013 04:20 PM
newnut
Aug 15, 2011 08:02 PM
badluck
Sep 16, 2009 08:16 AM
ddaren
Apr 5, 2007 12:16 PM
