Idle adjuster not working
Old May 31, 2019 | 12:45 PM
Jason Jones34's Avatar
Default Idle adjuster not working
Need some help? My 2005 Honda cbr600rr is not going past 1rpms because the idle adjuster is not pushing back far enough the idle adjuster plate's. What can I do to fix this?
Old May 31, 2019 | 01:36 PM
CaBaRet's Avatar
Your going to have to put it back in there should be a spring on the cable end that goes into the throttle stop, bit fiddly but put that long spring over the threaded end of the cable screw it back in by turning the adjuster ****, hopefully the spring will still be on the cable end,once its in and engine running adjust idle speed
Old May 31, 2019 | 08:23 PM
The spring is over the idle screw it's just when it's compressed all the way as far as it can go the idle adjuster has moved but not much. The idle screw that is on the bike is from a bad throttle body the original one I had broke off so I had to use the idle screw from the bad throttle body which was still good
Jason Jones34
Jun 4, 2019 01:14 PM
Ls1Mx5
May 18, 2015 07:32 PM
1iwilly
Jul 28, 2010 12:12 PM
Mike_Stunts
Sep 24, 2006 11:47 PM
BRC223
May 29, 2006 05:22 PM
