hot body fush mounts?
OK HERE'S MY QUESTION I JUST INSTALLED MY HOT BODY'S FLUSH MOUT TURN SIGNALS WHEN I NOTICE THAT NOW THAT THEY ARE INSTALLED MY REAR TURN SIGNALS STAY ON JUST LIKE THE FRONTS NOW..IS THIS NORMAL? ALSO WILL THIS CAUSE A PROBLEM ONCE I INSTALL MY INTERGRATED TURNS IN THE REAR? WILL I NEED A RESISTOR OR SOMETHING? PRECIATE THE HELP ...
Were the flush mounts 2 wire or 3 wire? If they were 2 wire you may have hooked the positive side up to the Honda parking light wire instead of the blinker wire. I hooked mine up with no resistors and they work fine.
yes there only 2 wires a red and a black...thats exactly what i did i hooked up both the turn signal and the parking light wire...so now i entend on disconnecting the parking wire and running it with just the turnsignal lights...cuz now everything is on..the front and rear turns and even the ones in the console.
