hot body fush mounts?
Old Jul 13, 2006 | 01:16 AM
wickedambush's Avatar
Default hot body fush mounts?
OK HERE'S MY QUESTION I JUST INSTALLED MY HOT BODY'S FLUSH MOUT TURN SIGNALS WHEN I NOTICE THAT NOW THAT THEY ARE INSTALLED MY REAR TURN SIGNALS STAY ON JUST LIKE THE FRONTS NOW..IS THIS NORMAL? ALSO WILL THIS CAUSE A PROBLEM ONCE I INSTALL MY INTERGRATED TURNS IN THE REAR? WILL I NEED A RESISTOR OR SOMETHING? PRECIATE THE HELP ...
Old Jul 13, 2006 | 04:58 PM
illmattix's Avatar
Default RE: hot body fush mounts?
Were the flush mounts 2 wire or 3 wire? If they were 2 wire you may have hooked the positive side up to the Honda parking light wire instead of the blinker wire. I hooked mine up with no resistors and they work fine.
Old Jul 13, 2006 | 09:01 PM
yes there only 2 wires a red and a black...thats exactly what i did i hooked up both the turn signal and the parking light wire...so now i entend on disconnecting the parking wire and running it with just the turnsignal lights...cuz now everything is on..the front and rear turns and even the ones in the console.
Old Jul 19, 2006 | 07:42 AM
johnnykhan's Avatar
Do they also works as riding light (always stays on)?
Old Jul 19, 2006 | 08:16 AM
HighRevver's Avatar
Your supposed to hook one to the ground wire and one to the blinker wire and leave the "parking" wire aka Hotwire out of the picture.
Old Jul 20, 2006 | 12:59 AM
thats exactly what i did..thanks for the reply fellas..i was confused for a second or two.
justbrowsing
Feb 9, 2009 07:16 PM
JerrilD
Sep 23, 2008 08:37 AM
PlayfulGod
Apr 8, 2008 08:53 PM
zorgen
Jul 1, 2007 04:21 PM
deeksmooth
Sep 8, 2005 08:19 PM
