Help Removing the rear plastic
Old 02-20-2006, 03:32 AM
SinaStar's Avatar
Default Help Removing the rear plastic
I am in the process of installing a Integrated tailight, and I have never worked this bike. This might be a dumb thread but can someone tell me step by step on removing the rear plastic on a 04 CBR 600rr. Thanks for the help.
Old 02-20-2006, 04:15 AM
929_erion's Avatar
Default RE: Help Removing the rear plastic
search for a copy of a pdf manual for your bike.
Old 02-20-2006, 12:37 PM
SinaStar's Avatar
I found one, but when i tried to download it, it said that it had problems...Do you have one that you can email me
Old 02-20-2006, 02:55 PM
sart by taking off your seat and rear seat/cowl. there should be about 6 screws. 2 holding the main seat, and 4 under the rear seat/cowl. there is also 2 push pins under the rear secions 1 on eash side right around your rear brake fluid resivoir and another on the opposite side, and 2 more by the gas tank under the seat. after that, use a little force and pull it out. and wa la.
Old 02-20-2006, 03:03 PM
It takes a little courage at first to bend the wings out enough to get the tail off...you'll feel like you're going to break it.
Old 02-20-2006, 04:46 PM
ORIGINAL: SinaStar
here you go bro...... http://www.stephygee.com/
Old 02-20-2006, 10:38 PM
cbr04's Avatar
ORIGINAL: Fretless33
EXACTLY how i felt the first time i took off the tail section
Old 02-20-2006, 10:53 PM
I think the only part that's missing is how to take off your rear cowl.....the keyhole is on the left hand side of the bike under the seat....
it's gonna feel like the plastic wont give....but it will!
Old 02-22-2006, 04:32 PM
so did you ever get it done???
bigswoll84
09-04-2021 03:10 PM
OrangeCapri
04-13-2013 01:46 AM
volitan
07-02-2010 04:42 PM
mrbret
11-30-2008 06:24 PM
transamlt1man
05-26-2007 05:45 AM
Quick Reply: Help Removing the rear plastic
