Help Removing the rear plastic
Old Feb 20, 2006 | 03:32 AM
SinaStar's Avatar
Default Help Removing the rear plastic
I am in the process of installing a Integrated tailight, and I have never worked this bike. This might be a dumb thread but can someone tell me step by step on removing the rear plastic on a 04 CBR 600rr. Thanks for the help.
Old Feb 20, 2006 | 04:15 AM
929_erion's Avatar
Default RE: Help Removing the rear plastic
search for a copy of a pdf manual for your bike.
Old Feb 20, 2006 | 12:37 PM
SinaStar's Avatar
I found one, but when i tried to download it, it said that it had problems...Do you have one that you can email me
Old Feb 20, 2006 | 02:55 PM
drag the knee's Avatar
sart by taking off your seat and rear seat/cowl. there should be about 6 screws. 2 holding the main seat, and 4 under the rear seat/cowl. there is also 2 push pins under the rear secions 1 on eash side right around your rear brake fluid resivoir and another on the opposite side, and 2 more by the gas tank under the seat. after that, use a little force and pull it out. and wa la.
Old Feb 20, 2006 | 03:03 PM
Fretless33's Avatar
It takes a little courage at first to bend the wings out enough to get the tail off...you'll feel like you're going to break it.
Old Feb 20, 2006 | 04:46 PM
cjbettis's Avatar
ORIGINAL: SinaStar
here you go bro...... http://www.stephygee.com/
Old Feb 20, 2006 | 10:38 PM
cbr04's Avatar
ORIGINAL: Fretless33
EXACTLY how i felt the first time i took off the tail section
Old Feb 20, 2006 | 10:53 PM
DudeyoursoooJDM's Avatar
I think the only part that's missing is how to take off your rear cowl.....the keyhole is on the left hand side of the bike under the seat....
it's gonna feel like the plastic wont give....but it will!
Old Feb 22, 2006 | 04:32 PM
cjbettis's Avatar
so did you ever get it done???
bigswoll84
Sep 4, 2021 03:10 PM
OrangeCapri
Apr 13, 2013 01:46 AM
volitan
Jul 2, 2010 04:42 PM
mrbret
Nov 30, 2008 06:24 PM
transamlt1man
May 26, 2007 05:45 AM
