HEAD LIGHT QUESTION
Old Nov 17, 2007 | 11:26 AM
Barlow527's Avatar
Default HEAD LIGHT QUESTION
Does anyone know of or where I can get a conversion kit for my headlights for both of them to be on on low beams and both onhigh beams? For example the R1 has it with an H4 bulb. I think they call it a dual stage bulb? Also is there any kits of there to make the little marcher light right under the wind screen brighter?
Old Nov 17, 2007 | 05:54 PM
Captain Slow's Avatar
Default RE: HEAD LIGHT QUESTION
Do a search for this. There is literally dozens of threads with this EXACT question. But to give you a short reply.
No. You cannot change out to a dual filament bulb because the headlamp housing was not designed for it. It's designed for an H7 bulb. That's all that will work with it. The low beam side is designed as a low beam, the high beam side is designed as a high beam.
You'll learn to live with it. Ride with your highbeam on ALL the time during the day, and at night, ride with the low beam (or high beam adjusted down slightly, your choice.)
Old Nov 17, 2007 | 09:20 PM
WhiteDealershipRice's Avatar
I was actually thinking about adding one or two small LEDs to the high beam side.
(Sorta like the "crazy eyes" mod, but either white, or veery slightly blueish)
And wire them to the low beam, so that the high beam housing would glow on a low intensity (kind of like a smoldering fire) while the bulb was off, but retain full high beam functionality.
Old Nov 18, 2007 | 12:30 AM
Blue Fox's Avatar
Retired Moderator
HAHAHA! I posted my comment under Captain Slow's login name. DAMN YOU LOGIN-COOKIES!
Anyway, you could wire the LED's to the "third eye" light. It should be easier to wire into that than the lowbeam (being that the correct amount of voltage is going to the "third eye" and more to the low beam.)
Old Nov 18, 2007 | 07:51 AM
Hadn't thought of that...
Thanks Fox!
yog182
May 29, 2013 01:23 PM
j-zee
Apr 15, 2012 11:59 PM
wood83
Sep 18, 2006 03:24 PM
wood83
Jul 23, 2006 01:58 AM
lang1864
Feb 1, 2006 11:37 AM
