gears
Old Jan 7, 2006 | 08:28 PM
6hundred_doubleR's Avatar
Default gears
has anyone had a problem with the bike slipping out of gear?
it has happend to me 3 or 4 times now. when i shift up into 6th gear it will slip out and rev up then fall into 5th gear.
Old Jan 8, 2006 | 04:17 AM
doncollins's Avatar
Retired Administrator
Default RE: gears
No... never happen to me.
Old Jan 8, 2006 | 10:26 PM
cjbettis's Avatar
Default RE: gears
I have never missed a gear...are you clutching it? 5 and 6 are close to each other
Old Jan 8, 2006 | 10:37 PM
ejohn's Avatar
Default RE: gears
the first thing i would do is check to see if you have any loose linkage in the shifter. make sure it is adjusted as the manual states or it will not go all the way into 6th gear.shift it by hand to see if the L clamp on the linkage is hitting anything.
Old Jan 8, 2006 | 11:58 PM
HighRevver's Avatar
Default RE: gears
That could be dangerous if you aren't expecting it, revving high then all the sudden slamming into gear.[:'(]
wisco
Apr 2, 2013 03:57 PM
danl23880
Sep 29, 2010 12:47 AM
boost90
Sep 24, 2007 02:46 PM
f4iguy8804
Apr 3, 2007 01:04 PM
Karl
Nov 13, 2006 02:32 AM
