Front fairing loose??
Hey everyone!
So I just purchased an 08 600rr the other day, cleaned her up to the best of my ability for the time being and I noticed a small problem, the black piece of plastic that wraps around from the front to behind the windscreen is a little loose, just a tad, but it's annoying me with my minor OCD complex.. Was wondering if anyone knew how to fix this, here's the pictures (I'll try and caption the problems in the pics):
This piece seems to be a tad loose too, the other side is tight
Pulling a little to show you the gap
I'm not sure if there is supposed to be a screw in that little empty hole spot, or it just floats there, I'm not sure, and there's about a 3mm gap that's truly annoying, anyone have any ideas what it could be? Thank you so much everyone in advance!!
Tom
Tom
Looks like you're missing a trim clip. I would check all the plastics for missing trim clips, pan screws, and worn/missing wellnuts. these are commonly broken/worn components that are pricey, but easily replaced. If you don't have a Honda Service Manual, I suggest getting one, or downloading one off this forum.
