Front brakes locked up.
Old 09-13-2011, 07:50 AM
pineypowerwpww's Avatar
Default Front brakes locked up.
So the other day I rode to work about 30 miles. Got there without a hitch. Went to leave and noticed that the bike would not roll tried to move and nothing. Come to find out my front calipers were locked up. Got a wrench and bleed the pressure off and Limped it home. Now I'm wondering what the hell is going on the bike is a 07 cbr 600 rr with only 2000 miles on it. Bought the bike in the beginning of the summer with less then a 1000 miles on it. Not sure if the fluid was ever changed or not but am going to do that now along with lines and pads. Is there anything eles I should do? Has this happened to anyone? Sure glad it didn't happen on the highway.
Old 10-10-2011, 02:07 PM
Anyone got any ideas why this happened.
Old 10-10-2011, 03:07 PM
estate4life's Avatar
February 2012 ROTM
Your caliper may have a seized piston? Which gets stuck and would not retract. Or maybe you have a warp disc rotor? But that's may seem odd.... scary issue here & best to have brake system thoroughly checks...
Old 10-11-2011, 12:20 AM
CBRfenatic93's Avatar
My guess is a stuck piston. If its a 07 with only 2k miles on it im guessing it sits a lot. So there is most likely a little bit of rust stopping the piston from retracting. Its a easy fix that you can do yourself.
If you need the know how let me know.
Old 10-11-2011, 06:22 AM
I was thinking something like that . Got the rebuild kit for both calipers (seeks and dust seals). Going to break them down this weekend and lightly sand the pistons to get off any surface rust.
Old 10-11-2011, 07:34 AM
74demon's Avatar
I find it odd that both calipers would just lock up at the same time after being parked for a day. Did they both have pressure just sitting there? An internally collapsed brake line or a faulty master can keep pressure on both calipers.
Old 10-11-2011, 10:32 AM
randyjoy's Avatar
Haven't added aftermarket levers? Common cause also.
Old 10-11-2011, 11:18 AM
Junior2552's Avatar
^^ Solid.
Old 11-03-2011, 02:26 AM
philthethrillohio's Avatar
had same problem. poped outthe pistons cleaned them bled the brakes and was fine. now my wheel spins all the way around not just 2 inches
Old 11-03-2011, 02:47 AM
itlnF4I's Avatar
im with the rebuild. a bike thats seen as much milage in 4 years as i put on my bikes in 2 months....is sitting WAY too much. you might be in for more than that in the future. might wanna tackle the rear caliper at the same time
ncsponger
01-13-2010 06:01 PM
6doubleohf3
10-25-2009 09:01 AM
Bigmize16
09-09-2009 09:30 PM
camcovert
03-05-2008 11:56 PM
cyber00677
08-16-2007 11:06 PM
Quick Reply: Front brakes locked up.
