downshifting
Old Apr 7, 2008 | 08:56 PM
B Marques's Avatar
Default downshifting
sorry for this newbie question, but when coming up to a stop and downshifting is it okay to downshift to 1st or once down to 2nd throw it into neutral? just wondering because in a manual car you dont downshift into 1st.
Old Apr 7, 2008 | 09:06 PM
D2VW14_20's Avatar
Default RE: downshifting
Yea, but apply brake too.
Old Apr 7, 2008 | 09:08 PM
Woody6799's Avatar
Yea you can do it anyway you like... just think of it as exactly like a manual car just nuetral is harder to find
Old Apr 7, 2008 | 09:24 PM
shoortbuss's Avatar
ORIGINAL: B Marques
That's entirely up to you...there's no protocol for this sort of thing, but I personally downshift to 1st on my bike and don't downshift at all in my car when coming to a stop. I like to kick the throttle when I downshift cause it sounds cool, so that's probably why I do it...plus the gears are great brakes on a CBR compared to a car.
Old Apr 7, 2008 | 09:31 PM
B Marques's Avatar
thnx guys for the help.
Old Apr 7, 2008 | 09:49 PM
Blue Fox's Avatar
Retired Moderator
I love to downshift to 1st when coming to a stop because you are using the engine to brake instead of the front end diving down when you use the front brakes only. I usually downshift and apply a little front brake at the same time.
Old Apr 7, 2008 | 10:35 PM
xxenycejattxx's Avatar
its okay!!! buh make sure the clutch is fully pulled and brakes are applied.
Old Apr 7, 2008 | 10:42 PM
spiderc's Avatar
In a manual car you dont downshift into first? Where the hell did you hear that? Why wouldnt you be able to downshift to 1st in a car?
Old Apr 7, 2008 | 10:46 PM
WoodyRR's Avatar
ORIGINAL: Blue Fox
I'd be surprised to know you don't apply rear brake at the same time. Is this a type-o?
I downshift anduse the engine brake to preserve brake pad life as well to let people know in the local vicinity that there's a bike near. Once you get used to your bike and get to know it really well, you'll be able to barely use the brakes at all when coming to a stop. Just a small, light application of F & R brakes to come to a complete stop. Just play around with it until you get a feel for the timing. Good luck.
Old Apr 7, 2008 | 10:57 PM
BadLag's Avatar
ORIGINAL: spiderc
because most of the time, the gear ratio is so short that you'd just grind it trying to force it into gear. happens on my rx7 when i try to downshift to 1st... even if i match the rpm's properly... i blip the throttle in my car just like i do on my bike but it still doesn't work.
