Chain and Sprockets
Old Feb 28, 2008 | 05:56 PM
03yellow6000RR's Avatar
Default Chain and Sprockets
This is something I wasn't planning on asking for a while. However, I just went up to the storage to let the girl get the juices flowing, and I noticed my chain has started to rust while she has been packed away. That being said, what manufacturer do you guys recommend, and where should I look. I definitely want the OEM set up, but don't necessarily want to pay dealer price.
Old Feb 28, 2008 | 07:28 PM
Red600RR's Avatar
Default RE: Chain and Sprockets
ORIGINAL: 03yellow6000RR
Hmmmmmm... those are some pretty tall requirements....BUT all is not lost. Everything I've ever read says go with a driven chain :
http://www.drivenracing.com/
As far as price goes welllllllll......if you surf long enough you'll find a good deal. Your not changing gearing correct?
Old Feb 28, 2008 | 08:14 PM
Keeping the stock gearing.
Old Feb 28, 2008 | 08:17 PM
bobjoezx's Avatar
just cause it has surface rust from being stored doens't mean it's shot.. but what is the info on it.. miles and condition of links? but a good way to fix it up in spring is to.. take it fully off, clean it with a brush and some soap water.. dry it. then lube it up very well!! that will take care of your problem depending
Old Feb 28, 2008 | 08:41 PM
Total miles on the bike 3072. The links and sprockets seem to be fine other than the small amount of rust. This is my first bike so I know I am probably being a little paranoid, but it is always good to be ready when the time comes.
Thanks for the help guys.
Old Feb 28, 2008 | 08:49 PM
bobjoezx's Avatar
o you have a good 10k miles left on that chian .. of course depending on riding habits but just do what i suggested to get that surface rust off and keep it lubed! you'll be fine
Old Feb 29, 2008 | 01:29 PM
RounderNU's Avatar
IM WITH BOBJOE! put some lube on it and ride it a bit, and it'll be fine[sm=yeahsmile.gif]
IF YOU WANT IT TO LOOK NEW AGAIN, YOU CAN USE NEVERDULL ON IT AND THE RUST WILL COME OFF. ITS COTTON WITH SOME KIND OF CHEMICAL ON IT, AND IT WORKS WELL
Old Feb 29, 2008 | 01:53 PM
Yea I have the lube already. I bought some with my last minor mod purchases, just haven't gotten around to applying it.
HydroPrelude85
Mar 6, 2013 09:00 PM
ganzey
Jan 31, 2012 03:15 PM
kowen1208
Apr 20, 2010 08:45 AM
NEboardr
Aug 7, 2008 11:20 AM
angryscientist
Oct 1, 2006 10:21 PM
