Chain preference
Old Mar 13, 2006 | 06:41 PM
duck0872's Avatar
Default Chain preference
So I went to make an adjustment and discovered I needed a new chain really bad. Any of you guys have any suggestions as to a tough-as-nails chain? or are they all pretty much the same?
Old Mar 13, 2006 | 08:03 PM
Tahoe SC's Avatar
Default RE: Chain preference
NO MANG...go DID and know the difference!
make sure you change your sprockets at the same time too.
Old Mar 13, 2006 | 10:07 PM
duck0872's Avatar
I was actually considering DID, either that or Regina. Now I just have to find a place online that sells chain and sprocket kits. Anyone know any places? I've already checked dennis kirk and ironpony, but no go so far. The search continues.
Old Mar 13, 2006 | 10:29 PM
cjbettis's Avatar
you gotta check out the sponsors for the site....they always hook you up!! bought my pipe through them and WAY good price....best I found
Old Mar 13, 2006 | 10:32 PM
NotSoMellowYellow's Avatar
Stick with 525 (stock) size if you want it to last a little longer. you can still change the gearing and the chain is stronger than the 520 conversion DID sells these with the clip-on type master so you need no special tools and the clips are stong enough for 600's I've been using one since I bought the bike just changed the chain and went with the stock chain and clip-on -1/+2 no problems except I can't seem to keep the front on the ground just gotta have wheelies.
I'll probably catch hell for the clip-on thing but I like it cause I can switch out the sprockets and even add lenght at will if I decide to do any crazy stuff with the gears.
Old Mar 14, 2006 | 09:34 PM
duck0872's Avatar
Thanks for the help guys. I ended up going with a 525 Regina ZR series chain and sprocket kit in original gearing. I'm pretty pleased cuz I ended up getting both sprockets with the chain for the same price that most places were selling just the chain for. And I figured what the hell, as long as I'm ordering something I might as well get a tank protector and some chain lube while I'm at it.
Old Mar 15, 2006 | 03:43 PM
Tahoe SC's Avatar
yea but mang...it's cheap cause you didn't do DID...
hopefully it's ok, but i've learned mah lessons...
as far as clip link, they fine as long as they are installed property, with the open clip end facing the back of the bike when the chain is on top. as far as lengthening the chain...you'll be running 2 master links...that is just unsafe...
T
Old Mar 15, 2006 | 07:26 PM
duck0872's Avatar
most of the places I looked had the regina and the DID chain for about the same price
Old May 9, 2007 | 09:33 AM
no1biscuit's Avatar
Does anyone know which sponsor has the best prices on Chains and Exhaust?
Thanks you all (it has been a while since I have been here)..
Old May 9, 2007 | 10:29 AM
98f3pilot's Avatar
quick question: does DID come stock on the RR? i ask because my used (1000k) stock 05 rr, (even still has the mud flap),has a silver chain with 'DID' on it.
Will1000RR
May 18, 2010 08:44 PM
Rod38um
Aug 11, 2008 07:29 PM
TyStrand
Mar 10, 2008 06:22 AM
pixel 6
Jun 10, 2007 07:28 AM
xcrusader12
Mar 16, 2007 11:23 AM
