Burning Oil
Old Jul 9, 2006 | 10:22 PM
Frerice's Avatar
Default Burning Oil
My CBR has burned about a 1/2 qt of oil since my last oil change, which was about 1600 miles ago. I plan to do an oil change in about another 1000 miles.[I've put a couple hundred miles on since yesterday morning] This will be its third oil change since I bought the bike new. I'll probably do an oil change next weekend since I'll be riding to work most of the days this week, that's an easy 200-300 miles or more dependin'.
Is burning this much oil between oil changes normal? I have to admit since the second oil change I have been riding more aggressive.
BTW I did add oil.
TIA
Old Jul 10, 2006 | 03:25 AM
13brsxsrr's Avatar
Default RE: Burning Oil
Do you do alot of stop and go riding? Alot of riding at night or during the day? What kind and weight of oil are you running? If you are using it alot as a commuter special the heat of riding in traffic can be culprate. I commute 3 times a week w/ mine and I'll consume less than 1/3 qt over 2,5K miles. I use Repsol 10W-50. It has no problem putting up w/ the abuse I give it.
Old Jul 10, 2006 | 09:30 AM
Frerice's Avatar
Yea, I do stop and go riding.
I'm using 10W-40 and I do commute, more like 5 days a week.
Thanks
Old Jul 10, 2006 | 12:05 PM
Fretless33's Avatar
If you do a lot of aggressive riding, that will burn oil, but 1/2 qt in the mileage you wrote doesn't sound all that bad...just a touch more than average for a sport bike.
Old Jul 10, 2006 | 12:36 PM
knightslugger's Avatar
Sure it's not evaporating? Some oils have a very high Volitility coefficant and when brought up to temp can loose a lot of substance because it's evaporating. Honest.
Check the Evaporative Heat Stability Test part to learn more
NE1000F
Oct 21, 2011 09:36 AM
__Z__
Nov 15, 2010 03:52 PM
spdbump36
Jul 2, 2008 05:44 AM
spdbump36
May 12, 2008 05:25 PM
JZHALES
Apr 3, 2007 03:20 PM
