Burning a little oil??
So i've been losing/burning a little oil and so i was wondering what i should do. It seems like i burn the most when i am starting the bike up and i see a little smoke. Either way people can smell it when they are driving behind me so what can or should i do. It only has 17k on it. Also would getting the valves adjusted help cause they probably haven't been done in a long time.
RE: Burning a little oil??
What color smoke?
White - Water in exhaust. Can be from blown headgasket or just condensation in pipes (which would only occur when first starting)
Blue - Burning oil. You can pull the plugs and check to see if any of them are fouled. Thicker oil might help reduce the leaking, but this is usually a sign of another problem. It could be leaking from the piston rings or the head gasket.
Black - Running rich. Adjust.
