Brembo RCS19 Master Cylinder install issue
Old Feb 17, 2020 | 08:13 AM
CBR_600f's Avatar
Default Brembo RCS19 Master Cylinder install issue
Hi all.
I've been trying to mount a brembo rcs19 master cylinder and ran into an issue with lever clearance on the stock bar controls and throttle wires. Basically the lever touches where the throttle wires are on the control when you pull the lever in. Has anyone has this similar issue using the stock equipment? I've seen others use a motion pro quick action throttle which had the throttle cables running higher over the tops of the handle bars. This means there's plenty of clearance, but it's quite an expensive way to fix the issue I'm having.
Are there any other ways round it?
I though about rotating the controls a little but they have a mount point which locates into the bar mounting hole. So it would have to be re drilled, but it would also mean that the control buttons would then point down and not be easy to press.
emefef
May 29, 2013 02:44 PM
Ian Gellman
Apr 4, 2013 03:55 PM
RoosterF3
Jun 24, 2010 03:47 PM
skip954
Dec 9, 2008 06:53 PM
flyguyeddy
Apr 21, 2007 01:09 AM
