Throttle Tube Replacement Issue
Old Apr 1, 2013 | 12:32 AM
Ian Gellman's Avatar
Default Throttle Tube Replacement Issue
Hey guys, I'm fairly new to the motorcycle world, and recently purchased a 2004 CBR600 F4i. I wanted to replace the stock grips with these Yana Shiki Aluminum grips. I replaced the grip on the left just fine, but when it came to the right side, I ran into an issue... I removed the stock throttle tube by loosening up the two bolts on the clip on casing using a wrench, and screwed off the bottom casing using a phillips. After a bit of a struggle, I managed to get it off, but now the problem lies in putting on the aftermarket throttle grip. I just cannot, for the life of me, get the throttle cables in the hole without a fight, and lining it up correctly. Is there a way to loosen up the throttle cable? By the way... I'm new to bikes Just throwing that out there lol I browsed the forums and web for hours upon hours, getting different results. All I essentially wanted to do was replace the grips. I didn't think it would be this troublesome. Thanks in advance guys. If you have any pictures of how to approach this, that would be awesome. :-)
Old Apr 4, 2013 | 03:55 PM
stillridin's Avatar
New Member
I am having the exact same issue. Luckily, I didn't break anything. I am surprised there are not many other posts about this!!!
sjona2011
Mar 1, 2013 08:18 PM
Xander F4i
Nov 23, 2010 05:37 PM
pointman
Apr 24, 2008 07:46 PM
