Blinker rate
Old Mar 16, 2010 | 08:59 PM
BigCat's Avatar
Default Blinker rate
I just put in new front and rear blinkers but they are blinking super fast. Has anyone had this happen? and what did you do for it? put in a resistor or something.
Thanks for the help.
Old Mar 22, 2010 | 02:17 PM
BDT's Avatar
BDT
What year is your bike?
For the 07-10 its a simple replacement of the turn-signal relay. You just remove the seat, unplug the old one and plug in the new one. Super easy.
http://www.customled.com/products/fl...sher_relay.htm
I'm not sure about the 03-06 but the above relay doesn't work for it.
Old Mar 22, 2010 | 04:51 PM
AgentRR's Avatar
April 2010 ROTM
If the new blinkers are leds then they dont draw enough power for the bike to see them. What that means is that the ecu thinks the bulb is blown so it blinks rapidly to let you know. So you have to add a resistor inline to trick the ecu into seeing power draw. That will slow down your blink rate...
Omaha rider
Aug 6, 2011 10:39 PM
moorejr21
Feb 10, 2009 06:22 AM
rider0033
Jul 23, 2008 08:22 PM
ocf4
Jun 22, 2007 12:05 PM
rio_600RR_06
Aug 24, 2006 11:05 PM
