Blinker Flash Rate Help
Old Feb 6, 2009 | 07:42 AM
moorejr21's Avatar
Question Blinker Flash Rate Help
On my 97 F3 the right side front/rear blinkers flash faster then the left side, I replaced the turn signal relay NO luck. I have aftermarket flush mount fronts and the rear are stock, could it be a wiring problem? What can I do to fix this?
Thanks
Old Feb 9, 2009 | 01:32 PM
SIRR1's Avatar
First check your wiring.
Also it could be a wrong sized bulb in one of the 4 blinkers drawing less amps on one side making the blink faster...
Old Feb 10, 2009 | 06:22 AM
Sproutf3's Avatar
Registered Users
If your flush mounts are i think its called single filliment then its going to blink like that, the fast blink is the blinkers saying i have a blown bulb. The front blinks are supposed to be running lights, so if you put lights that only blink and dont run the bike thinks something is wrong and blinks quick. Look for dual fillament flushmounts to correct the problem..it could possibly be a wiring problem but more likely just wrong blinkers...i see it all the time around here
__Z__
Feb 2, 2011 01:58 PM
BigCat
Mar 22, 2010 04:51 PM
drunkinmist
May 14, 2009 04:28 PM
ocf4
Jun 22, 2007 12:05 PM
