Blinker Flash Rate Help
On my 97 F3 the right side front/rear blinkers flash faster then the left side, I replaced the turn signal relay NO luck. I have aftermarket flush mount fronts and the rear are stock, could it be a wiring problem? What can I do to fix this?
Thanks
Thanks
If your flush mounts are i think its called single filliment then its going to blink like that, the fast blink is the blinkers saying i have a blown bulb. The front blinks are supposed to be running lights, so if you put lights that only blink and dont run the bike thinks something is wrong and blinks quick. Look for dual fillament flushmounts to correct the problem..it could possibly be a wiring problem but more likely just wrong blinkers...i see it all the time around here
