600RR Swingarm Width
Old Jun 27, 2008 | 06:02 PM
swiest152's Avatar
Default 600RR Swingarm Width
Does anyone know what the pivot width of the 600rr swingarm? I tried searching but nothing came up that I needed.
Not sure if this should be posted in this board or the mod board.
thanks,
sw
Old Jun 27, 2008 | 11:15 PM
swiest152's Avatar
Default RE: 600RR Swingarm Width
Also, what is the diameter of the swingarm Bolt?
from what I saw in the RR swingarm to f4 conversion thread, the RR SA and F4 SA are the same width?
Old Jun 27, 2008 | 11:21 PM
PlayfulGod's Avatar
they are the same width n same bolt dia. The RR uses a larger axle tho, so you will have to either make bushings for the F4/i axle or find bearings that fit the F4/i wheel and the rr axle. Will also need a 1000RR shock, flip the upper shock mount and grind it so it fits.
Old Jun 28, 2008 | 09:45 AM
swiest152's Avatar
Im not looking to put the RR swingarm on a f4. My friend has a f4, so I was just checking to see if I could use that to measure the width on the f4 to get the RR width.
Thanks for your response.
Old Jun 28, 2008 | 07:27 PM
swiest152's Avatar
How does the width of the 03-04 RR swingarm compare to the 05+ rr swingarm?
Old Jun 28, 2008 | 07:52 PM
PlayfulGod's Avatar
ORIGINAL: swiest152
think they are the same. the upper shock mount is casted in with the rest is the biggest difference I think.
Old Jun 28, 2008 | 09:25 PM
swiest152's Avatar
ORIGINAL: PlayfulGod
ORIGINAL: swiest152
03-04pivot bolt goes through the engine, frame and swingarm where as the 05+ only goes through swingarm and frame. I dont know if all the RR frames are the same.
MMMichael
Sep 20, 2010 06:21 PM
devlzluv
Feb 20, 2008 03:17 PM
Harry
Jul 18, 2007 11:02 AM
wsideshow
Apr 9, 2007 07:41 PM
