600 rr normal temps
Old Dec 27, 2006 | 10:18 PM
98f3pilot's Avatar
Default 600 rr normal temps
I did try a search first but didn't come up with an answer. Today I rode my bikein 37 degrees (farenheit)weather in city traffic, (not heavy) and noticed the temp around 178 while moving and at stop lights going up to 200-215 degrees. I'd expect these temps if it was summer, but in cold winterish weather, is it cooling properly?
Old Dec 27, 2006 | 10:34 PM
Kearnsy's Avatar
Default RE: 600 rr normal temps
Seems a little strange mate but not too much to worry about as long as you got coolant in the over flow tank. These bikes do run warm. I had mine up to 106 c /222f before the fan comes on. Usually seems to run about 180f when its 86f air temp . Its always up and down pretty quickly when im in traffic. hope this helps mate
Old Dec 27, 2006 | 10:41 PM
98f3pilot's Avatar
I haven't ridden in the summer so I don't have anything to compare. Temp goes down as soon as I start moving and there is fresh coolant in the overflow tank. Fan comes on around 220's too.
Old Dec 28, 2006 | 12:32 AM
bushmasterAR15's Avatar
You'd think they would be cooler but those are of the norm.
Old Dec 28, 2006 | 05:04 AM
Blue Fox's Avatar
Retired Moderator
My temp is usually around 180 when I ride for a while in 30-40 degree weather. If I run around in stop and go for a while, I see 200 sometimes to 210 degrees on brisk day. I wouldn't worry about it too much. (in fact, I just got home from a friends house (yes I rode), and it's 21 outside. Just pull the bike into the garage and it was at 189 degrees.)
Old Dec 28, 2006 | 11:29 AM
cjp48's Avatar
I was surprised by the same thing, so apparantly its normal.
During summer it runs at 200 while riding and quickly jumps to 215-220 at
a stop light.
During winter (in VA my coldest ride has been around 30) it runs around 170-175 while
riding, and will jump to 215 at a longer stop light.
I figured as long as its fluctuating,and the fans kick in at 220, then everything is working !
Chris.
Old Dec 28, 2006 | 05:02 PM
vipkat's Avatar
I was worried when I bought my rr, never saw that on my last bike, but you guys must be rite, its by design. I even replaced my coolant this summer with water wetter and it didnt make too much difference so it must be ok.
Old Dec 28, 2006 | 08:35 PM
98f3pilot's Avatar
yep, i get the same readings in cold weather.look like from all the replies it's average torun hot even in winter.im having a blast getting used to, riding and cornering on the rr. such a responsive bike.if the '03-'04 areso much fun, i have to wonder what the'05-06 are like.
Old Dec 29, 2006 | 03:04 AM
Blue Fox's Avatar
Retired Moderator
The good thing about a bike running warmer than others during the winter months is heat roll off. You can warm back up at a stop light by hugging your bike. AND the undertail exhaust (on longer rides) keeps your **** toasty too. lol.
TwoBrothersBusa
Oct 19, 2013 05:18 AM
sofakingtore420
Aug 4, 2007 09:17 PM
chrisf
Oct 4, 2006 09:09 PM
gregp
Oct 1, 2006 07:07 AM
malbojah
Aug 1, 2006 09:31 PM
