1st time - Front wheel of the ground??
Old Sep 30, 2007 | 12:52 PM
dave_p's Avatar
Default 1st time - Front wheel of the ground??
Hi, I've had my 600rr for 4 weeks now from new - covered about 1500 miles - all very steady and safe!! I'm now starting to open her up in 1st, 2nd and 3rd - shifting at about 12500rpm. In 1st and second the front wheel is almost about to come up. I don't yet have the experience to pull back on that throttle to lift it off the ground a couple of inches - how hard is that?? Can I just close the throttle very slightly to put the wheel back on the deck after lifting it a couple of inches or will all hell break loose????
What are your first experiences of this??
Old Sep 30, 2007 | 06:16 PM
transamlt1man's Avatar
Default RE: 1st time - Front wheel of the ground??
There is nothing to be afraid of. Getting scared and closing the throttle fast will result in a nice slam of the front tire on the ground and thats about it.
Old Sep 30, 2007 | 07:21 PM
oodie's Avatar
February 2009 ROTM
You will be fine my first time was when i went from first to second really fast didn't letout ofthe throttle all the way and it clutched up so fast scared me really good.Lol I let go of everything to get it back down but now i do it on call.
Old Sep 30, 2007 | 08:23 PM
knightslugger's Avatar
ORIGINAL: dave_p
it really depends. 2nd gear is nothing to be afraid of especially if you've already gone up to 12,5 in 1st because third isn't that far away and it'll be settled in by that point. keep your weight forward as you accelerate in first and second. if you slam the tire down it could send you into a non-recoverable tank slapper.
Old Sep 30, 2007 | 08:29 PM
Hatebreed's Avatar
get a steering dampner... and youll be fine just dont panic. if you really start to get that wheel high tap your rear brake. but if you come down hard your steering might get a lil squrily and thats pretty scarey. but if you just ease off the throttle you should be able to set it down smoothly.
Old Sep 30, 2007 | 09:13 PM
crashkhanman's Avatar
+1 on the Steering Damper. If you are going to be doing this or any type of hard riding get one of these. You do need to watch out when you come down. If you come down with your front wheel not so straight ..this could put you into a "tank slapper" and those are never fun. Also like someone before me said ..cover your rear brake ... if you go up to high just tap the rear brake to bring you back down.
Yes, to put her back on the "deck" when the front is just a couple inches off the ground you can ease off the throttle and it will set back down.
On my stock '07 under WOT (wide open throttle) and my weight a little further back then what it should be ... I've only experienced the front wheel slowly pulling off the ground about a foot total, starting around 12k and going til I shift at around 14.5. When I shift from 1st to 2nd at around 14.5k the front wheel usually comes up around 1.5 - 2 feet.
bluej511
Mar 16, 2008 07:38 PM
A4wheelin
Aug 7, 2007 12:57 PM
chimmike
May 26, 2007 10:42 AM
japanese900rr
Aug 15, 2006 11:52 PM
