07+ Throttle Body on 03-06 RR head?
Old Aug 24, 2011 | 10:18 AM
segraves1's Avatar
Default 07+ Throttle Body on 03-06 RR head?
Can the "new" throttle body (and computer) be used with the older cylinder heads?
Old Aug 29, 2011 | 12:00 PM
amRRussel's Avatar
<--Me subscribing for the answer.
Old Aug 30, 2011 | 09:03 AM
TucsonHonda's Avatar
Good question. I have a friend with a 05 and his is torn down to replace the gas tank. My 07 is torn down to check clearences. I took a look at both and it looks like they match up but I can't be sure. I didn't check if the injectors were different or if you would have to use the old or new...Not sure but I will be watching for the answer if someone knows.
Old Aug 30, 2011 | 11:29 AM
segraves1's Avatar
It looked to me like they should fit, however I did notice the fuel rails, injectors, and injector plugs all looked difference, so it might be that the throttle bodies are interchangeable, but require the same year wire harness (or change plug ends).
nicolas.
Aug 22, 2015 05:50 PM
zellster
Sep 29, 2010 02:42 AM
Stiggs
Jun 24, 2010 10:20 PM
dizzie56
Nov 30, 2006 06:29 PM
