06 with 3 break?
Old Nov 5, 2013 | 07:42 AM
Killerdimpler's Avatar
Default 06 with 3 break?
I was thinking of buying a 06 for pretty cheap, but the only problem is its been stunted out. I have some concerns it has three levers for breaking. One up front and two levers for the back calipers . Is this easy to reverse? Also the tachometer doesn't work at all. I would love to hear anyone's thoughts
Old Nov 5, 2013 | 07:46 AM
BRezmer's Avatar
the brake issue should be fixable but you have to think of how many times that thing has hit the ground. the tach maybe due to tail light harness unplugged(if it has a working tail light, im no help)
Old Nov 5, 2013 | 09:41 AM
Conrice's Avatar
Yeah, all it has is a rear brake lever underneath the clutch lever. This is for being able to slow down a wheelie while sitting on the tank.
You'd need to remove the second rear caliper that's hooked up to the front line. You'll also have to replace the caliper bracket with an OEM one that holds 1 caliper. And obviously, remove the 3rd lever on the bars plus the line that runs through the bike to the rear. Nothing too hard to do. And you could probably sell that set up to someone who stunts and make some money back. I'd look over the motor and the frame to make sure it was running correctly and straight. If it was, I wouldn't worry about the other stuff. The tach could be a few things. Worst case, you'll have to replace it.
Post some pictures of it or the CL ad or whatever.
Old Nov 6, 2013 | 08:38 AM
The tail light does work. It's an 06 That has a crash cage. Dude was selling it for $2500.
Grego2582
Mar 27, 2013 06:13 AM
raylee
Mar 8, 2010 10:57 PM
alleycat
Oct 10, 2007 11:20 AM
ctskydive
Aug 20, 2007 05:23 PM
Drekkyk
Jun 9, 2007 12:00 PM
