Where to hook up sync tool
Old Aug 13, 2008 | 04:40 PM
Aweasel's Avatar
Default Where to hook up sync tool
So I made a manometer to sync my carbs but I'm not sure where the vacuum port/lines are I need to hook it up to. On other bikes and I've seen there is a port for this specifically but I don't see any on our carbs. Anyone that knows where to start, I would really appreciate it.
The only place I could imagine to hook into is the small vacuum lines that go right behind each velocity stack on the air box.
Old Aug 14, 2008 | 08:39 AM
DonEverett's Avatar
Default RE: Where to hook up sync tool
WHen you remove the lower part of the airbox, there will be 4 small rubber tubes connected to the back side of it. Those are the tubes you need to use. The ones not in use will need to be plugged.
compster
F2 Tech
29
Jun 5, 2012 12:28 PM
kray923
Jun 2, 2010 02:06 AM
CBRfenatic93
Sep 10, 2009 02:33 PM
88_F
Nov 2, 2007 12:48 AM
