Transmission/Shifting Problem
Old Aug 24, 2008 | 06:27 PM
mattrw1's Avatar
Default Transmission/Shifting Problem
My 99 F4 starts perfect but when I let the clutch out in first to ride from a stop the bike bucks and chugs. The problem seems to get worse as the bike gets warmer. I've read a lot of posts about problems with 2nd gear - but not too many with my problem. Any ideas?
Old Aug 25, 2008 | 12:18 AM
808 cbr f4's Avatar
Default RE: Transmission/Shifting Problem
mine was givving me similar problems and turned out to be the regulator rectifier... fixed now..read the post i made and give some results of the battery voltage.
https://cbrforum.com/m_625775/tm.htm
hope it helps, at least eliminates a problem
Old Aug 25, 2008 | 10:21 AM
edubF3's Avatar
Not sure if this will help, but I think Ifelt like I had this problem on my old F3. It turned out to be the clutch cable needed to be adjusted. Good luck.
Old Aug 25, 2008 | 12:47 PM
emperor wurm's Avatar
^^^ I agree adjust your clutch cable, depending on milage, you might want to replace your clutch.
Old Aug 26, 2008 | 11:58 AM
mattrw1's Avatar
Thanks for all the advice. After reading the other posts, I've narrowed the problem. The clutch cable doesn't seem to be the problem.
The bike runs well until the fan kicks on. Once the fan is on, at low RPM's it wants to die. If I come to stop, it bucks and sputters when I try to take off (or it dies completely). Thw fan is draining the battery and at low rpm's, it isn't being charged so there isnt enough to keep it sparking correctly.
Based on what I've read, I think '808 cbr f4' is right about being the R/R. Before I spend $100 on one, I'd like a second opinion. Some of the posts I've read about this problem say its a carb or pump problem. Anyone? Any advice on where to buy a new RR / which part to buy. Any thoughts on buying a used one online?
niner29
Apr 24, 2009 06:42 PM
herman pahls
Sep 4, 2008 06:44 PM
chiquita100
Apr 8, 2007 02:51 PM
al
Nov 30, 2005 02:36 AM
stinger95
Sep 8, 2005 08:05 PM
