954 transmission shifting
Old Mar 5, 2005 | 11:33 PM
al's Avatar
al
Default 954 transmission shifting
I recently bought a 2003 954(first sport bike), although I love the bike, it seems that the transmission shifts really hard. Is this true for all 954's (or all sport bikes) or is this just mine?
Old Mar 5, 2005 | 11:51 PM
sirlimpzalot's Avatar
Default RE: 954 transmission shifting
Try changin the oil to synthetic or a synthetic blend if you havent already, since the oil is used in the clutch, trannsmission, pistons, ect...the " slicker" oil may make the shifting smoother. It worked on my CBR using Motul 300V (@$50 a gallon) or Golden Spectro oil ( about $8 a bottle)
Old Mar 6, 2005 | 05:38 PM
al's Avatar
al
thanks for the advice, I'll give the different oils a try and see if it helps.
Old Mar 7, 2005 | 07:07 PM
RumbleFish's Avatar
I'm currently running Motul 300V (full synthetic) and the shifting is still a bit 'notchy'...My understanding is that this is normal.
RF
Old Mar 8, 2005 | 01:54 AM
HONDA is notorious for having CLUNKY transmissions especially going into first gear
Old Mar 24, 2005 | 11:22 PM
reevesna's Avatar
i personally wouldn't recomend synthetic or blends because of the reported/rumor that synthetics break down the friction plate fibers...depends on how "clunky" your clutch is...said this was ur first sport bike...what'd u ride before this one
Old Apr 1, 2005 | 02:37 AM
wheeliemonster's Avatar
I would be very carefull using a full synthetic oil. Your bike has a wet clutch which means its in the oil. It does need some friction. a full synthetic oil may cause your clutches to slip. I put a synthetic blend in my 954 for a season. I ended up going back to the standard honda motor oil. I found it works the best for hondas. Honda bikes, mine anyway, seem to be alittle more sensetive in this area. My Yamaha loved the Golden spectro synthetic blend. Not so much with the honda.
Old Apr 2, 2005 | 03:03 AM
al's Avatar
al
thanks for all the asdvice. know its gettin a few more mi. on it it seems to shifting better all the time.
Old Jun 15, 2005 | 06:35 PM
bwp777's Avatar
I have used synthetic oils and never had a problem with shifting. Most oils now that are made for motorcycles will work just fine and most of the time better. Got to the Amsoil website and look at their wear rating verse the rest. It is superior by far. I'm having trouble with my transmission however but I'm calling Factory pro for their shift kit .
Old Nov 25, 2005 | 10:00 PM
9fiddyfo's Avatar
not with amsoil
