throttle loose
Old Aug 21, 2006 | 12:46 AM
Murph317's Avatar
Default throttle loose
so my throttle turns about 1/2" before it actually engages. i've looked at it quickly and dont know if there is a way to get rid of the extra play before the it engages?
Old Aug 21, 2006 | 03:05 AM
ajlong's Avatar
Default RE: throttle loose
You can adjust it on the cable. The adjustment point is where the cable is comming out the throttle at the bottom...just past the elbo, you'll see a lock nut and a threaded sleeve, that's where you make the adjustment, adjust it to your liking without making so tight it increases the idle of the engine. I think all you need is a 10mm and 12mm wrenches. There is also an adjuster at the carbs/throttle bodies, but you shouldn't need to adjust that one.
Al.
cbr6rider
Apr 20, 2011 08:57 AM
Gacho
F2 Tech
Apr 6, 2011 04:13 PM
zellster
Sep 29, 2010 02:42 AM
jtjr008
Mar 15, 2010 05:59 PM
leishman
Jun 14, 2006 08:48 PM
