Thread Pitch of Exhaust Stud
i have searched the forum and havn't come across the correct answer yet, while removing my header to paint it black, two of the studs have broken off. my question is does anyone know the thread pitch of the nuts and studs that connect the cylinder head to the exhaust manifold/header i would like to source these from my local autoparts store since they are 2 weeks out if i have to order them from my honda parts supplier catalog shows them as a 7mm but doesnt not define the pitch to 7x1.00 or 7x1.25 etc
any help would be greatly appreciated. thank you in advance
With the investment you've got in your ride, I'd recommend replacing them all. They are cheap enough, and if two broke already,
they've probably all been over-torqued and/or tightened out-of-sequence.
If you soak them good, with break-free, and then, maybe, a touch of heat, I bet you can spin them loose.
I won't swear, but I think the pitch is different, on each end, coarse for engine, fine for header plate nut.
Good luck, Ern
Good luck, Ern
