stock F4 fork height setting?
Can someone please give me the stock fork height on an F4. Specifically, I need the distance from the bottom of the neck (from the lower bearing spot) down to the center-line of the axle. I can not use actual "fork height" as it would relate to triples since I am using a 929 triple and GSXR forks.
Can you tell me how thick the lower triple is? I don't have my F4 lower triple anymore so I have to calculate my setup from the frame itself.
Hope this helps.
